  • 1 Reply
  • 2976 Views
roberthacker1
after hearing the chime while viewing the bar code installation does not progress.  The camera then makes a two tone buzzer sound and reverts to a flashing amber light.  I'm adding the camera to a system with two current cameras.  I have turned on and off several times.  Rebooted computer without results.
Do a full reset of the Q cam...hold in the reset button for about 10 sec til the led flashes...
Attempt sync again as  if new.
( older Qs had problms with special charactors in the SSID/Password for the wifi  ( not knowing you version if it was sitting in stock a while ))
