  • 2286 Views
paronsson
Hi, what is the working temperature for Arlo Q wired? Thanks
JessicaP
Hi @paronsson,
The Arlo Q is indoor only.
paronsson
Hi Jessica,
It is in my summerhouse and in the winter it is a bit cold in there.
Any idea if +10 degrees Celsius is ok?
Per
Especially with the heat generated by the camera in operation, you should have no issue. +10C is about +50F, well within specs.
