  • 1 Reply
  • 1890 Views
pearljammer
Hello,
I have a quick question about the Arlo Q and whether or not I should purchase it. I am on ADSL with only 1mb upload speed and it cannot be increased. I have a doorbell cam that uses 500k upload speed and it works just fine. If I understand correctly, by adjusting the settings on the Arlo Q I can possibly make it work with my 1mb upload. My question is this; given my slow internet speed, would I have any problems having the doorbell cam and the Arlo Q both on my wifi network? I'm assuming the cameras are only using the upload speed while they're transmitting so I would think I would be ok, but wanted to make sure.
This may help; you may be able if you lower the rez....
which you can manually lock into a lower setting
