Web site stuck at log in page. Spinning circle for a few seocnds and nothing.
  • 6 Replies
  • 4792 Views
Brillo
I havent used my Q Cam for a while, today i set it up on my android smart phone and can access video etc, so i know my account is good......
SO i decided to log on to my account on my PC using Chrome, went to the log in page, put in user name and password, clicked login spinning circle for a few seconds then nothing. left it for a few minutes... nothing.
so opened the app on my phone and it said i waas logged in elsewhere, so i had logged in on the PC but the home screen had not come up.
SO i cleared the cache etc etc asnd tryed again, no good, so i tryed EDGE browser, same problem..SO for the sheer hell of it i set up another account which i did  went to the log in page and the same problem occurred it wont load the home page of my avccount....
What am i doing wrong??
The login page address i am loading is https://my.arlo.com/#/login
JessicaP
I would suggest to contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link
6 REPLIES 6
Are you still seeing this?
Brillo
Yes i am and have been for the last two days ever since i fired up the Cam.
JessicaP
Hey Brillo,
Have you tried on incognito mode on Chrome and/or Edge to see if that helps?
Brillo
Yes i have tried both , and have exacvtly the sdame problem.
JessicaP
Brillo
Hi,
I did contact support they suspected it was Kaspersky antivirus causing the problem, they were right, Kaspersky are looking into it the Web Anti-virus component is causing the problem.
