  • 6 Replies
  • 334 Views
NDY
Pushing the reset pin nothing happens, just stays solid amber
6 REPLIES 6
Any reset button needs to be held for a long time to actually cause a reset. If you help at least 20 seconds, that should be enough. However, make sure the battery is charged first.
NDY
I reset to factory, removed from app, when I press sync it won’t turn blue. No battery just plugged into outlet
NDY
Yes
NDY
Yes
NDY
No battery plug in
ShayneS
It appears you may be experiencing hardware failure based on the device not factory resetting. If a factory reset doesn't resolve the issue, you may need to consider replacing the unit.
