  • 5 Replies
  • 2834 Views
MVaneman
I have five arlo cameras.  All have worked ok, and I have had them for years.  Just started getting push notifications randomly from all cameras.  I have always had my setting set up to send limited notifications, but now I get them all the time.  This is frustrating.  I have notifications off for one camera because it is in the front on a busy street, but now I am getting push notifications from it.  Since I changed nothing in my phone or arlo profile, this must be an arlo issue.  I tried restarting my iphone and updating all apps, but that did not fix it.
5 REPLIES 5
Have you checked that the cameras doing this are still listed in in your subscription plan?
Have you checked the rules in the mode(s) you are using?  https://kb.arlo.com/42/What-are-modes-and-rules-and-how-does-Arlo-use-them
Do you use the geofencing feature?
MVaneman
Of course.  The rules are the same as they have always been.  And the notifications are not consistent with the rules that I have been using for years.  I did check them though just to make sure they were not somehow changed, and they are not.
I am seeing some other users reporting this, so it might be an Arlo bug.
I had some from one camera today. I checked the push notification box, saved and then unchecked and saved. So far, so good.
MVaneman,
If you toggle all smart notifications on/off and reboot your camera/base station. Do you still see the same behavior?
