  • 8 Replies
  • 720 Views
MGRANDEY
Trying to add an Arlo Q camera to my system. The camera is not being recognized.???
8 REPLIES 8
ShayneS
Hi @MGRANDEY
Can you try factory resetting the device with this article here and try again? https://kb.arlo.com/000062665/How-to-factory-reset-an-Arlo-Q-or-Arlo-Q-Plus-Camera
MGRANDEY
I reset several times.  Still can't get camera recognized.
ChrisNg
I also got exactly the same trouble too.
Even I have fully followed the steps to factory reset the camera.
No matter through the web or mobile app, both of them will return an error "camera not found"
ShayneS
@ChrisNg Based on the information provided, this may indicate a hardware failure. If a factory reset on the device using the steps in this article does not resolve the issue, you may need to consider replacing the unit.
ChrisNg
That response from @ShayneS suggesting a hardware failure is unacceptable.
I’ve reviewed numerous posts about reconnecting Arlo devices after a factory reset, where the device fails to be detected by the Arlo app or web interface. In most cases, these issues seem to occur with devices that have reached EoL.
However, when I connect my Arlo Q Plus via Ethernet cable, I can see it listed on my router’s device list. It clearly attempts to establish a connection with a server hosted on AWS.
Additionally, I own another set of Arlo devices that are still under active support. These devices also connect to the same range of AWS-hosted IP addresses without issue.
Based on this, I strongly believe the problem is not related to hardware failure. It’s more likely that something on the server side—specifically AWS—is preventing my Arlo Q from registering properly.
ShayneS
@ChrisNg
I sent you a pm, please let me know if you received it.
Thank you
ChrisNg
@ShayneS
no, there is no PM from my message box
ShayneS
@ChrisNg Thanks for letting me know, can you check your inbox again.
