  • 73 Views
franco_
Hi I'm trying to add Arlo Q.
We have 2 Arlo Q working since many years and now trying to add other two never used before to the same Wifi router but can't add. The process fails after readind qr code and beep sound is prodused.
It may be that since they were unused for a long time, the FW may not be updated to allow them to work.
Check the current firmware on the ones running...   I'm running  ( ver end info )  3500e
franco_
it makes sense but still can't find how to connect and then update.
If you have the to-old firmware problem, then there is nothing you can do to fix it.
