  • 1 Reply
  • 1322 Views
Alexi60
Hi trying to sync my Arlo Q It was unplugged for 5 days Now when I’m trying to sync it searchs for WiFi makes a buzzing sound than turns back to yellow tried this 5 times help
The manual has the following suggestions:
If you hear a buzz sound, try the following remedies:
  • Check to ensure that you entered the WiFi network name and password correctly. The WiFi network name and password are case-sensitive.
  • Try moving your Arlo Q camera closer to your WiFi router. Do not place your camera farther than 300 feet (91 meters) from your WiFi router.
Also, if you are onboarding from the app, you might try onboarding from a PC (browsing to my.arlo.com).
