Streaming Church Services for elderly
If my church had internet service would they be able to stream live masses for approximately 1 hour with the arlo q without any problems?
No...the Arlo Q cams are not designed for streaming..... You would need a regular ip cam.
The Arlo Q can stream 24/7 without breaking in any way.
Keep in mind thet you can only be logged on the same accont on one device.
Also you can use a 4G router or personal hotspot to provide internet to the camera and use a battery pack for power.
Thanks for the info.
I wasn't thinking about being logged in on one device only at a time.
That wouldn't work if multiple people wanted to view the Church service
During my testing if you use the grant Access option https://community.netgear.com/t5/Arlo-Knowledge-Base/How-do-I-add-friends-to-my-Arlo-account/ta-p/40 and each person having their own account it would work. Have not tested the maximum number of people simultaneously but 2 worked fine so a assume unlimited.
You may also consider contacting Netgear Support for further assistance.
Arlo Q
