  • 7 Replies
  • 3674 Views
c_fuller
Q suddenly stopped working after many months of uninterrupted use.
Following the instructions I found on the website, I performed a reset of the camera and removed the camera from the app. But I am unable to add the camera back to the app.
After going through setup steps, the device does not appear and an audible (error style) tone is heard from the camera.
7 REPLIES 7
ShayneS
Are you connecting to the same 2.4Ghz network your device/phone is on when setting up?
Do you have the latest version of the arlo mobile app installed?
You can also try performing a factory reset if this doesn't help.
FWIW, the Q can connect to 5 Ghz.  But if you use the same network name for both bands, then it might be useful to try disabling your 5 Ghz network while onboarding
c_fuller
Thanks for the reply, much appreciated. Still after going through setup steps, the device does not appear and an audible (error style) tone is heard from the camera.
Replies…
Yes
Updated the app via the app store
Performed reset
c_fuller
Replies…
Disabled 5 Ghz network
c_fuller
I am still seeking help for this issue. Can anyone please help me to get this camera setup again? Thank you!
c_fuller
Anyone – I am still seeking help for this issue. Can someone please help me to get this camera setup again? Please help!
It's certainly possible it's just a dead camera. However, you said you reset the camera - did you hold the button until the camera clicked and the LED started flashing amber?
