  • 8 Replies
  • 3673 Views
marc543
Arlo Q
No subscription
No Arlo smart hub
I have no more recordings in the history since I added another Arlo camera ( essential indoor; I know this one doesn't support history) however the Q should do or did that change ?
8 REPLIES 8
@marc543 wrote:
Arlo Q
No subscription
No Arlo smart hub
Nothing should have changed for the Q.
How many cameras do you have all together?
marc543
The Q and the essential indoor
@marc543 wrote:
2.
Then you should still be getting recordings for the Q.
Can you make a manual recording while livestreaming??
marc543
Right now I can't connect to it at all..it just keeps saying "connecting"...
Unfortunately this always happens when I'm not at home..
BrookeN
Are you still seeing the same behavior?
marc543
Recordings are back up after I reset and disconnected the camera at home.
It's a bit annoying though if it happens while you're away.
Is there any way to do this remotely?
BrookeN
You can restart the basestation from the app, but you can. not reset the cameras remotely .
No, but you could remotely reboot the Q using a smart switch (since it has no battery).  That could resolve some issues.
