I need a USB power cable that is about 4 feet longer than the one suppled with camera. Does Netgear sell longer power cables. or can you recommend an alternative cable brand?
I don't believe Arlo sells a longer cord or certifies any 3rd party power adapters with longer cables. Adding a 4' power cord would be the easiest solution. Or switch to an Arlo-Q Plus and use POE. I'm not sure if you can just power a Q Plus using Cat-5e with a POE injector and still use WIFI for connectivity. I haven't tried that configuration and it is not documented in the manual. But if you could connect it to Ethernet, you could power it over Ethernet as well.
Arlo Q
