  • 2 Replies
  • 2230 Views
Steve07805
Hi,
Do you think I will be ok to mount my Arlo Q on the top of a radiator? It is a central heating radiator... ie the type of heater that is water filled and is heated by a central boiler.
I am not sure what temperature they get to but it is ideal as the Arlo Q magnet sticks it nicely in the corner of the room.
Thanks!
You could try it.  The Q camera runs warm to the touch (not hot ) and does have a thermal cutoff if it gets to hot as some saw in the summer when placed in sun...
But prob not a good idea overall.
TrulsZK
You can place an insulater between i.e. Something that is not conducting heat
