  • 7 Replies
  • 2699 Views
Stevenfrenchy
Hello there
quick question, is there a device to make my Arlo Q Poe connected ? I don't want to sell it and buy an arlo Q plus, looking online I can't seem to find anything.
thanks
7 REPLIES 7
Nope. The regular Q is WiFi-only.
Stevenfrenchy
thanks for your response, after doing research I was thinking to get that device to make it compatible? do you think that may work?
https://www.amazon.co.uk/gp/product/B01H37XQP8/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
thanks for reading
Don't know internal specs of what Arlo uses.... prob only way to know is to try it ( and return if it doesn't work )
Stevenfrenchy
yes agree, I have ordered it, hopefully that won't a fire hazard.
will update it to see if that works
I guess it depends on what you're trying to do. I was assuming you wanted an Ethernet connection which isn't possible. Using that PoE splitter will work for power (theoretically) but still won't allow an Ethernet connection.
Stevenfrenchy
I was just interested on power as I have an access point near the entrance, let's see how it goes.
Stevenfrenchy
okay so
test is 50/50 but will stick to it, the device give power over ethernet however the ethernet cable  is cat 3 and doesn't give power which is odd, so I had to add another ethernet cable cat 6 but at least I now have the camera up and running without power cord.
