  • 1 Reply
  • 2127 Views
TheProfessor
Blue light is on the front.  Says connected to Arlo servers but in settings says WiFI is disconnected.  Video has a delay too it.  Is all this normal or should I do something to improve video feed and Wifi conntection?
Reset the Q camera by holding in the reset for about ten sec.... re sync as if new.
Mind that if the led is blue/purple, it may be that the Q cam is at the max range for your wifi.
