  • 1 Reply
  • 2134 Views
Barb56
300 miles away. Receiving message , "Your device is not connected. Make sure it's connected to your router and has a working internet connection". These are only hooked up by wifi.. Will I need to drive there to get these working again?
JessicaP
Hi @Barb56,
You can try to restart your Arlo Q remotely to see if that helps. You can do this by going to the Arlo app/web version and go to Settings > My Devices > Your Arlo Q > Scroll down where you see "Restart." Otherwise you might need to check on your router to make sure it is working properly.
