I have 2 Arlo Q's and only one works
I purchased my first Arlo Q in February 2018. I chose it over other cameras due to the online software viewing options.
I bought a second Arlo Q in July 2018 and I have had nothing but problems with it. It took longer to discover the 2nd one and after a while it could not be detected viewing the online software.
I took it down & reset it & went through the discovery process again & it would work for a short while then go missing again. Once, I unplugged it for more than 24 hours & plugged it in and it worked for about a day, then it would go offline. (Your device is not connected) I got to a point that I haven't viewed the software online for months because I'm sure that the 2nd is not working. I just use my D-Link cameras. Just to rule out a strength of signal issue, I bought a wifi extender and still I could not see it online. One of my D-Link cameras is very close to it & it is working fine. (None of the cameras are really that far from the router anyway. What was I thinking?)
Now the 2nd Arlo cannot be discovered. I've tried through the phone app, my wireless laptop, my desktop, & it will not be discovered. I tried about 25 times today. I've tried every combination of factory reset (holding reset for variable lengths of time) unplugging it, resetting my wifi, & it is nowhere to be found.
Today, I went to Amazon & I see that I'm one of many who've had major issues with the Arlo Q. (Major issue being that it just does not work) I actually thought of buying another Arlo Q, thinking I just got a lemon on my second try, but I think I've come to my senses and will be looking elsewhere.
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
						Activity Zones1
						Apple TV App1
						Arlo Mobile App22
						Arlo Pro1
						Arlo Q30
						Arlo Smart2
						Arlo Web and Mobile Apps1
						Arlo Wire-Free5
						Before You Buy112
						Features149
						Fehlerbehebung1
						Firmware Release Notes15
						IFTTT (If This Then That)7
						Installation354
						Online and Mobile Apps135
						Online und mobile Apps1
						Other Discussions1
						Service and Storage2
						Smart Subscription1
						SmartThings5
						Troubleshooting1,117
						Videos50
