Do all models work in same app
  • 5030 Views
Tadcrazio
I just purchased the new Arlo baby to use as a baby monitor in the bedroom. But I'd like to ideally use the Arlo q or another product in the Arlo family to use in the living room. What I would like to know is if all Arlo products use the same app. So can i see in my baby's room with the baby cam and in living room with the Arlo q in the same app?
Thanks.
Yes, the apps and the web support all of the Arlo cameras...
The Q and Baby will appear in the same screen as the other Arlo cameras ( Arlo , Arlo Pro, Arlo Pro2 )
The only diif is that the cameras that use the base units can all be armed/disarmed/schedule as a group while the Q and Baby must be armed/etc on their own ( as they have no base and hook directly to your home wifi )
Tadcrazio
I appreciate that. So do I need a base station? If I were to buy an Arlo pro would it just work in the app or do I need a base station?
The app will allow you to see/manipulate all Arlo devices in one fell swoop.
To add any of the wireless cameras, a base station is required - it's the only way to connect them. Only the Q and Baby cameras are self-contained.
