Cannot find any power cord that is compatible with Arlo Q. Only see for Pro, Pro 2, Go, and Light.
  • 1 Reply
  • 1630 Views
bfreed01
I cannot locate any power cord that is compatible with the Arlo Q.  I see them for Arlo Pro, Arlo Pro 2, Go, and Security light -- but none for Arlo Q.  Would a power cord for an Arlo Pro work with an Arlo Q?
It's just a microUSB connection but the plastic surround can be the issue for fitting it to the camera. If you have one that you want to try, plug it in and see if it will work. If it can't be fully seated, use a knife to (carefully!) shave the plastic until it does fit.
You can also try the Contact Support link at the bottom here to see if they can arrange for one to be sent.
