  • 4 Replies
  • 2482 Views
timeasterday52
I left my Arlo Q unplugged in the garage for a while and just tried getting it going again. It was flashing amber so I thought it needed to be setup again. I deleted the camera from the app and wanted to add it back. However, the app only allows me to choose Ultra, Pro, or Essential cameras. I see no choice to add my Arlo Q. Any advice?
Can you access the web at MY.ARLO.COM
it is listed under camera others
PS on android also as Other... no ios in my hand
( jeff yu beat me )
On Android, at least, there's an Other Camera selection under Essential. You have to scroll down to see it.
timeasterday52
There is no choice for Others in the IOS app. Only if I log in via my PC. I brought the camera in and was able to get the PC to setup the camera.
Reboot the phone and reinstall the app. If still missing, use the Contact Support link at the bottom here to raise the issue.
