Easiest thing to do first is RESET the camera ( hold reset for ten sec till the led flashes ) and then resync
RickFritz,
Adding to the suggestion above, do you see the same behavior regardless of the viewing device you are signed in to? Do both the mobile app and web client show the same behavior?
RickFritz,
It sounds like this issue is isolated to your iPhone. Consider rebooting your phone and try again. Do you still see the same behavior?
RickFritz,
It very well could be an issue with the phone. Do you have any other devices (other than the iPad which you know works) that also have the same behavior?
Arlo Q
