Same here and also with my Arlo pro 2’s They no longer show any recordings in the app and only record when manually triggered from the app.
What mode are you using? (the default "Armed" or a custom mode)
If you create and use a brand new custom mode with rules for motion detection, do you see the same behavior?
I have tried both armed and custome modes; same result... I can live stream, and I notice motion detection working, but it wont record as I have set it to. Very frustrating. I think it all started after the last update.
Do you have CVR? If so, this is a bug on Arlo's side. See this thread:
https://community.arlo.com/t5/Arlo-Q/ArloQ-CVR-stopped-recording-to-Library/td-p/1653304
I have the same issue, but only on the two cameras I have CVR enabled. Like you, the motion detection looks like it's working (both motion and SD card icons turn orange), but no recording happens.
I have a Q on CVR and get most, but not all, recordings. I do suspect that CVR is the cause but what you're seeing and what I am doesn't match. I have done nothing for some time other than to change WiFi a few months ago. It is not on Smart.
Thank you for the clue, jguerdat. I deactivated Smart and rebooted the camera, and now finally I was able to trigger a motion event that went into the library. It might be fixed now.
Arlo Q
