  • 4 Replies
  • 1128 Views
arnie24
I have the Arlo Q, it will not scan the barcode from my iphone 6 or screen on macOS Mojave, not getting a chime.
I have restarted the camera by unpluging it and using the reset button.
I reloaded the app and started again many times.
I have a very fast internet connection, my passwords are all correct.
It just does not want to work.
Can you help please?
When you reset the Q, it was plugged in and you held the button until the camera clicked and the LED flashed amber, right?
arnie24
Yes that is right
It seems this is a new camera so swap at the store. Otherwise, open a case with support here:
arnie24
Thank You
