  • 10 Replies
  • 4352 Views
charlestrike
Hi My Arlo Q would not connect to the network. When I added the device to my account. It can not be discovered. I have tried resetting it with the small pin on the side. Remove and add the device but no avail. Tried with apple and the android app still no good. However, my other device arlo baby is working 100%. My arlo Q stopped working after the big update.
Please help
10 REPLIES 10
When you used the reset button, did you hold it until the camera clicked and the LeD flashed amber?
charlestrike
Hi jguerdat
Thank you for your reply. Yes, I did that already. Hold the reset button for 10 seconds till light is flashing amber. I connected it with android and apple devices but still not working. After the big system update my arlo Q is no longer detected on my wifi or could not connect.
Thank you again
Open a case with support here for faulty hardware.
ShayneS
charlestrike,
Do you have a screenshot of the error message?
charlestrike
Yes please see attached. I really want to talk to someone to fix this. Thanks
ShayneS
Have you tried contacting customer support regarding this issue? I have attached the link below for you - Arlo Tech Support
Tambrew
My Arlo Q is doing the exact same thing. I purchased it when I purchased my Arlo 2 Pro camera set. I have tried several times to add it to my Apple device and it goes all the way through ... but never connects. Any suggestions? I haven't been able to add the device at all.
ShayneS
Tambrew,
Have you tried to reboot the camera and try again? Are you connected to the same wifi you are installing on?
charlestrike
Yes, I have reboot and reset the camera. I am trying to connect it to the same wifi that we have. Everything was working well until the new update. Suddenly, my Arlo Q was no longer connected whereas my Arlo Baby which same connection is working well. Unfortunately, I can no longer connect my arlo Q. I am hoping someone can check the hardware for me ie. service center?
thanks
Open a case with support here:
