Arlo Q won't Sync to me Linksys 1200AC router
  • 1 Reply
  • 738 Views
Rickb2020
Installed the Arlo Q  1080 HD but it will not sync to my Linksys 1200AC WiFi.    Did a reset to Arlo, Changes password on the router, verifivied the Wifi name is correct, I have tried syncing it many times.  I sync and the blue light turns on, but when I show it the product code, the light stays blue for a few seconds then turns red and I get is Buzzz.. Does anyone know why this  would not sync.  it is very frustrating to buy a product and it does not work.
ShayneS
Hi @Rickb2020
  Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
