Installed the Arlo Q 1080 HD but it will not sync to my Linksys 1200AC WiFi. Did a reset to Arlo, Changes password on the router, verifivied the Wifi name is correct, I have tried syncing it many times. I sync and the blue light turns on, but when I show it the product code, the light stays blue for a few seconds then turns red and I get is Buzzz.. Does anyone know why this would not sync. it is very frustrating to buy a product and it does not work.
Hi @Rickb2020
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
Arlo Q
