  • 4 Replies
  • 1860 Views
MikeMcKee
I have had the free basic 6 camera plan for yers and my 6th camera (Arlo Q) went offline on 9/29 and I cannot reconnect it. Anyone else have this problem?
JessicaP
Hi MikeMckee,
Do you see any LED light showing from your Arlo Q?
MikeMcKee
LEDs light as expected when adding camera. Then it changes back from blue to amber and it makes a failure sound. Tried a brand new camera and got the same results.
JessicaP
Make sure that your phone device is connected to the same WiFi network that your Arlo Q is trying to connect to and make sure you're typing the SSID and PW correctly.
fbh
Same issue here. I dont know whats going on but Arlo is falling apart.. Constant issues..
I have two Arlo q devices that are disconnected (per the app) at my beach house.. im not there to physically work on them so im out of luck until I get back down there... Problem is I remotely restarted the router and they reconnect to the router again just fine.. but not to the Arlo servers..
Arlo constantly releases new firmware that does nothing but screw up cameras, apps, etc.. They better get it together because the other product manufacturers are starting to blow them away.
