  • 2 Replies
  • 1455 Views
ArloUser99
I have two Arlo Q cameras both running firmware 1.9.0.0_269 and experiencing two problems.
1) The camera periodically stops recording, I log into the app and there have been no recordings for a day, if I reboot the camera the issue is fixed. I shouldn't have to reboot the camera to maintain a working solution.
2) Both cameras are about 3 metres from one of my Google WiFi points and are periodically showing the blinking purple light that means low WiFi signal. For example, this morning I looked at one of the cameras and it was showing 1 bar of strength, I rebooted it and it now shows full signal strength. Other than rebooting it anything I can do to fix this?
I have tried factory resetting the camera but still experience the issues.
Are you sure the Q camera is hook into the close wifi feed... I had an issue where my Q was hook into the wrong wifi access ( which I only found out after going into router and satellites )
ArloUser99
Thanks for the response. It looked like one was connected to the closest and one wasn't, so still a little odd that they were both showing the purple light. My understanding is that there is no way to force a device to connect to a specific Google Mesh point.
My biggest concern is the devices stopping recording.
