Arlo Q missing video settings
  • 12 Replies
  • 5791 Views
Elmooro
Hi all, the video quality on my Arlo Q is poor when I'm sure it used to be good. I think it might be down to a low resolution but the only visible setting in the device settings is the brightness - no optimization or resolution. I'm running the app on a Google Pixel 2, am I missing something?
12 REPLIES 12
I don't have my Q hooked up right now but on other cameras it's called Power Management these days. Have you looked there?
Go to Settings of Q camera, rez is under Video Setting
Elmooro
The settings are missing from the device settings page so suspect it's an app issue, reinstalling app didn't help
ShayneS
Hi @Elmooro
Is this setting missing in the Arlo Mobile app and web? What App version are you using on your phone? Is it possible to provide a screenshot?
Elmooro
Hi ShayneS, missing in the app but can't seem to log onto the we to check. App version is 2.12.2_27010, screenshot attached. Cheers
ShayneS
@Elmooro
What OS version is your phone running?
I was not able to replicate this issue on a pixel 3 App 2.12.12 (Android 10) & iphone 11.
Have you tried to remove & re-install the app?
Elmooro
Pixel 2 XL running android 10. Reinstalled app status remains the same. Just installed app on my wife's Pixel 2 XL and all settings visible.....?
ShayneS
@Elmooro
Are you a granted access user/account?
Elmooro
How can I check that, do I need to log on via the Web?
ShayneS
@Elmooro
Are you the owner of the system with the admin account? Did you set up the Arlo base station & devices & create an account?
Elmooro
Yes it's all mine on my account, no base station just 1 x arlo q
ShayneS
Hi @Elmooro
I apologize for the confusion, I miss read the thread. Have you tried to perform a factory reset on the Arlo Q?
