Arlo Q minimum operating temperatures
  • 2 Replies
  • 1837 Views
flexg
Can an Arlo Q work in an un heated garage where rain is not an issue just freezing temperatures?
Should be no problem but the lowest temp in the garage could be an issue. The fact that the Q uses AC power may keep it warm enough to not shutdown due to low temps but you'd have to test. Got a freezer you could stick it in for testing?
I feel it should work fine..... esp since the ac powered Q does run warm ( as it is recording all the time )
A long time ago, I tested a batch of battery cameras in a freezer and they worked fine to -4F
