Arlo Q how can I remotely reconnect the device to the network?
  • 1 Reply
  • 3926 Views
floydj
I have an Arlo Q connected to a wireless network in my condo.
Sometimes the internet disconnects and the Arlo isn't working.
When I am traveling and something like this happens, how can I remotly reconnect the device to the network?
Thank you!! Floyd
The Q camera SHOULD auto-reconnect to the wifi when it comes back... If it doesn't due to a long outage the Q may require to be unplugged / plugged in.
Remotely is a hard issue cause your problem is the wifi outage.... You could try a Wemo ac plug ...this allows you to turn on/off the outlet via wifi.
Of course your wifi must be back on for this to function too.
check here; http://www.belkin.com/us/F7C027-Belkin/p/P-F7C027/
