  • 4080 Views
HugoDiaz
Cams do not reconnect -- no power outages, no apparent router reboots --  BOTH cams loose connectivity and STAY out of servce.  To drop connectivity is ok, it will happen-- the reason why it drops is not relevant -- but cams must save the password and reconnect without human intervention. This requirement ( I would bet on) should to be part of your design document but it was not implemented.
This is a significant BUG.  In the world of QA it's called "incomplete deployment" -- guys please fix it and give us an honest schedule, we see reports for this issue a couple of years back.  It has to be a known issue in your shop because it is easy to reproduce.
Have 2 cameras; the cottage is one bedroom/bath and a living area; the router is no farther than 20 feet from the cams.  It works very well in general.
Serial Number 4SS16CSW2E9C8 cam1, version 2.4.4_17405 Relased 6/29/17
Thank you,
Have you tried and reset the Q ?
HugoDiaz
Correction -- Model is X VMC 3040 | Arlo-Q HD with Audio
about reSync the cam
it requires physical presence to read the QR code.  No help there
Kremmen
I've only had one instance so far but it does look like an internet interruption does mean a power cycle is needed to get it to search for the router.
My other camera system, fortunately, keeps trying to connect after either a power or internet disconnect. I got the ArloQ as a backup to my other system so I'm covered by 2 different companies systems.
