Arlo Q disconnects from network
  • 6 Replies
  • 4566 Views
ollewis
Lately my Arlo Q are disconnecting from the network.
One had been working for a month with no issue, but now goes ut daily.
I have another that disconnects regularly from the start
There is no way to reconnect that I can see, other than resetting it up
Lewis
6 REPLIES 6
Check the LED on the front of the Q cam.... if you see it blinking sort of purple, your at the max range for usability
ollewis
I did not notice that. They are currently all connected so I will wait until next event and let you know
In the mean while I moved the hub away from my router, since somewhere on line I saw that could be an issue (too close)
ollewis
It is now going offline every 20 minutes.
The light in the front is a red/white/blue combo, but is not fdlashing.
It is only abou 40 ft from the hub, which is 10 feet from the router
Remember that YOUR home wifi system may have a lower powered signal when compared to the arlo base station.
this means a less  or lower distance to the router.
gb4loans
Software is difficult (not intuitive) to navigate. Mine also just kind of randomly disconnects. The only way I have found to re-connect is to set it all up again. Very time consuming
Random disconnecting is indicative of poor WiFi which can be due to distance, blockage (walls, ceilings,mirrors, TVs, etc.) or interference from other wireless devices, not necessarily WiFi. If you have more than line camera, swap cameras and see if the issue follows the camera or the position.
