Arlo Q - cannot connect to talk but can see and hear.
I just purchased the camera and set it up yesterday. Can see the area from the camera perfectly and hear what is happening clearly on my iphone, but cannot get the microphone to work. All settings appear to be proper, but when I press on the microphone it says "connecting" and never connects.
Don't know if I am doing something wrong or if it is the connection or the camera. Firmware updated as soon as I plugged the camera in.
First thing is to check the app in settings on the iphone and make sure it has permissions to use the mic
I would also test the Q camera via a PC to actually see if it is working or if the issue is phone related.
( at https://arlo.netgear.com/ )
krinks,
Do you see the same behavior when using the web client on a PC? What model iOS device and carrier do you have?
lemonch,
This is currently being investigated by the engineering team. I will post an update as soon as I have more information.
This is exactly what's happening with me too. I can push to talk from my iPhone as long as I am on wifi, but it doesn't work on LTE/cell networks.
I am having the same issue with Arlo Q. I can hear the sounds when live. If I speak you can not hear me at the location of the camera however since there is about 5 to 8 seconds delay between what is going on at the location and the feed back on my cell I can hear my voice played back on my phone. I have and Iphone 7 plus and T-Mobile is my service provider. I check the setting on my phone and Arlo is not blocked on my privacy setting and the Arlo app has been granted access to the microphone. I do not see anything else that I can check. Is the camera defective? Does is really have the capability of two way communication.
Imcleo1,
Consider testing using a computer via the web client to further isolate the issue. Do you still see the same behavior?
homeforus,
The engineering team is currently investigating this issue.
Same thing happenign with me too. Really need a fix.
More than month has gone by with still no fix for this.
I am really considering filing a complaint for false advertising. Their product does not work as advertised.
homeforus, Imcleo1
This issue is specific to T-Mobile devices. Engineering is still working to resolve the issue. I will provide an update as soon as I know more.
Your engineers have been working on the issue for what 3, 4 months since I bought the camera? What are we supposed to do in the meantime? I specifically looked for certain features when I bought the camera and two way talk was one of the features I was looking for. Your response does not help the fact that the camera does not have two way talk if you are using T-Mobile and that should have been disclosed because if it had, I would have not purchased the camera. I have my cell phone with me at all time, I do not carry my computer and/or laptop around with me all day long. I have not even try to see if it works with the computer, it does me no good.
JamesC wrote:homeforus, Imcleo1
I have access to AT&T iPhones and a Verizon iPhones. I will test this out and report back. In the meantime, I should tell everyone that push to talk works fine on my T-Mobile phone on Ring cameras and Nest cameras.
I am having the same problem with the mic not connecting while using Tmobile data. Thought the problem would go away once I upgraded to iphone 8 plus. However, that is not the case. Same old problem. I have been waiting patiently for a solution from Arlo's engineer, but my patient is wearing real thin.
JamesC any update from Engineering?
I bought the camera in May, reported the problem in June after trying several ways to solve the problem. 3 months later, they expect me to pay to return the camera so it can be exchanged. Mind you, they know there is a problem with the camera, the advertise a feature that does not seem to work for many and they expect the customers to pay to return a defective product that does not do what it advertises to do.
My camera refuses to update from FW version 1.74_5517. It's stuck.
That was the way it manifested for me also. What FW version does your camera have? Newer FW is supposed to fix the push-to-talk isuue. My Arlo Q was however unable to update to the latest version, hence I returned it to the store and got me an additional Arlo Pro camera instead.
Arlo Q
