  • 3429 Views
VWhelan708
From what I've been seeing, weak wifi signal can be pretty common with the Arlo Qs. I'm, of course, having the same issue, but with only 1 of my 2 Qs. Both of them are in the basement. In this first photo, you see my basement stairs. Right across from the opening to the stairs is where the wifi modem and the Arlo base are set. Now move to the next photo.
In this photo, you see the bottom of the basement stairs. Right across from the stairs is a room where one of the Qs has been placed. We have ipads and iphones and have no issues with the wifi signal in that room. Almost a foot behind this picture is where the other Q has been placed. The one that is closest to the stairs is the one that has the weakest signal. It only shows 1 bar and sometimes just freezes or drops off. The second one has 2 and sometimes 3 bars. No issues with this one at all.
Thoughts on what may be the cause?? It is up above a tv and cable box, so I don't know if that could be an issue or not.
VWhelan708
Thanks for your reply!! And yes, we have duct work AND a mirror in there LOL!!! Oops! Guess we'll have to look into an extender!
wifi blockage can be from metal duc work in the wall/ceiling, mirrors , etc... hard to tell.
But the good thing is the Qs work very well with wifi extenders and some times you have to expand your home system.
VWhelan708
Will say that the range of the Qs are based on your own home system wifi....
I myself found my home system to be on the weak side compared to the Arlo base  ( looking for a new home system now )
