Arlo Q Replacement Wall Plate
  • 1 Reply
  • 2314 Views
TheDukeofNY
Where can I buy a replacement wall plate for my Arlo Q? Can't find on site or anywhere else. Thanks
Arlo discontinued it in 2019 (long after they stopped selling the cameras). They continue to support all the Arlo branded cameras and base stations (which I believe were launched in 2015)
Tho I do see used units for the range of $50+ on like Ebay .
Or the only other thing I can think of is to epoxy a connection on the back side for a normal female side camera mount. Then you can use any standard camera mount with 1/4-20 thread.
like below;
https://www.amazon.com/CAMVATE-Female-Double-Adapter-Extension/dp/B07P94Z1QH/ref=pd_lpo_2?pd_rd_i=B0...
