Since the last firmware update (around Feb?) this camera will not connect to my home network.
1. I have tried resetting a number of times. The camera does all the usual clicks when resetting and then I get an amber flashing light.
2. Go through setup procedure and all is fine thus far. I 'show' the QR code to the camera and can hear the chime.
3. As soon as I click Continue I get a 'buzzer' sound which is four descending notes - and the camera LED starts flashing amber again.
I have tried numerous resets. Tried setup on several iOS devices. Tried setup on several Android devices. Tried setup on no less than two PCs and three laptops. Always the same result.
I really am hard pressed to recommend Arlo to anybody as I had a lot of trouble when it *was* working, but now it's just a very expensive paperweight.
Please advise.
Have you opeed a case with support for a possible warranty issue?
Hey @Imwalther,
I would suggest contacting our support team (with the link that jguerdat posted) if it's showing "getting status" message if you already tried a factory reset and reinstalling the Arlo app.
Hey @g3niu5,
Could you clarify what problem you are having when you are saying that your Arlo Q won't connect? Are you seeing an error on the Arlo app or on the web client? What steps have you tried to troubleshoot?
Make sure your phone is connected to the same network that you're trying to connect your Arlo Q with. If you're still having problems, try to do a factory reset by holding the reset button for about 10 seconds. Then, you'll hear a click and see the front LED flash and then try re-syncing again.
						Activity Zones1
						Apple TV App1
						Arlo Mobile App22
						Arlo Pro1
						Arlo Q30
						Arlo Smart2
						Arlo Web and Mobile Apps1
						Arlo Wire-Free5
						Before You Buy112
						Features149
						Fehlerbehebung1
						Firmware Release Notes15
						IFTTT (If This Then That)7
						Installation354
						Online and Mobile Apps135
						Online und mobile Apps1
						Other Discussions1
						Service and Storage2
						Smart Subscription1
						SmartThings5
						Troubleshooting1,117
						Videos50
