After app added extra security, device was no longer connected and can't find again.
  • 1865 Views
redsoxfan44
Luminary
Luminary
I've been using Q for a few years trouble-free.  My network/router is unchanged.  Yesterday, the Android app made me re-login and instituted new security 2FA protocols.  I went through all that and at the end there were no devices connected.  I went through the standard cycle, reset, Add New Device and got the amber, the blue,chime but at the end of a long try, it can't find any devices.
Fwiw, the blue/purple light doesn't continue to blink after the sync button.  It just goes on and then goes off.   I think that's okay, but not sure.  I do get the chime after  the QR code.
What is going on?   Has my Q been bricked by a new app requirement?   I don't get it!!!   Very frustrating!!
redsoxfan44
Luminary
Luminary
fwiw, i reset my modem and updated the app.  no change.  arloq shows in my network on the router device page.
2FA has nothing to do with the camera connection - it only affects the login process.
Are you using the same login credentials as before? Since you reset (did you hold the button until the camera clicked and the LED flashed amber?) did you also remove the camera from your account before trying to add it again?
redsoxfan44
Luminary
Luminary
Oh, I should have updated this thread.  Thanks for replying.
At my wits end, yesterday I tried logging out and logging in again and voila!  My device and everything was just where I left it!    Just another dumb app.    Usually when apps change something in the login, even a password, they make you re-login.
