  • 2 Replies
  • 2091 Views
Larry22222
I have 3 ArloQ (wired) cameras connected to my wifi. I need to add a 4th camera. Problem is...no access to electricity. Is there a similar wireless camera that will connect seamlessly to my existing system?
Thanks...you are all great Americans
Essential, Pro 4, and the Pro 5s cameras can all be connected directly to your home wifi. So can the Pro 3 floodlight (but not the regular Pro 3).
One drawback of the Essential is that the battery is not removable.  One consequence of that is that you cannot reboot the camera if it misbehaves, instead you need to do a factory reset.
All of these will require an Arlo Secure subscription to get cloud storage and activity zones.
Larry22222
Also...need one that I can setup activity zones...
