  • 7 Replies
  • 10608 Views
  • 6 Likes
  • 6 In Conversation
mmarkid08
I was wondering if anybody has any experience on continuous live streaming from the Arlo Q or Q plus?
We've recently got the Arlo Pro 2 system which doesn't quite do one of the things we need it to do.
Essentially in our office, we have a camera in the entrance which we then live stream into various Offices so we can see who is coming and going. The original camera died and we decided to upgrade to the Arlo Pro 2 system and cover more areas.
The problem we have is that the feed for the Arlo Pro 2 cameras constantly times out after 30 minutes of live streaming which isn't really going to work for the purpose we need.  We have it plugged in also.  We've also tried not turning on the live feed and seeing if the feed is triggered to start when it detects motion - no luck so far.
I've seen the CVR option mentioned, but unless this resolves the issue with Live viewing/streaming timing out this isn't going to work for us. We don't need it to be constantly recording (the motion detection recordings are fine) we just need to be able to stream it without interruption.
So, this brings me on to my question, does the Arlo Q or Q Plus allow us to have a continuous live feed on screen without timeouts?
Do we need CVR to allow us to have a continuous live feed without the timeout as well as the recording?
Or should we look at another solution for this purpose?
7 REPLIES 7
brh
@mmarkid08
Here is the link that says with the right subscription plan with the Arlo Q, Q Plus and Baby cameras 24/7 recording is possible.
https://www.arlo.com/en-us/products/subscription-plans.aspx
Brian
mmarkid08
I'm not sure you have understood my question.
The question was, is there a way to have a constant live feed without the feed timing out. We need to be able to monitor the camera in real-time (give or take a few seconds delay), without the constant timeouts. Having to footage recorded isn't a priority here.
Reviewing the footage isn't going to be suitable even with the email alerts as they take too long to come through.
Thanks.
brh
@mmarkid08
Here is another link that says that the three previously mentioned cameras can record non stop 24/7
https://kb.arlo.com/000039104/Do-Arlo-cameras-record-24-7
Brian
The Arlo cameras Arlo/Pro/Pro2 all time out in about 30 mins .
 For live streaming to a tablet/phone/computer...
The only cameras that will stay on is (possibly) the Q cam ( it use to NOT time out and I have run it for a hour or two but haven't tested the latest FW updates, still think it does )
OR
The Arlo BABY  will stay on 24/7  ( and yes the animal ears come off and its a simle round white ball ) .
That's the only choices you have
Echo5Mike
We have the standard Arlo and Arlo Qs.
The Qs don't time out the way the standard Arlo does but the stream does regularly stop/freeze after a few hours.
Closing out the stream and starting it up again will result in an unable to stream message.  The only way to get it back is to stop the stream and wait about 30 minutes and try again or to just power cycle the Qs by unpluging them.
As a workaround we plug the Qs in though smart outlets so we can 'unplug' the cameras remotely.
DShannon
Been using the Arlo Q (VMC3040) for a couple of weeks now. I cannot get it to stop timing out and logging me out on the web feed. Earlier comments seem to have some confusion around constant recording and constant feed. as the previous commenter, I am not looking for a constant recording. I just want an always-on visible live feed.
Further to an earlier comment, I can see not wanting to send the traffic through their servers to the website view. Given that the camera is running on my internal network, an app that feeds the view internal to my own network seems like a good solution.
Just to be clear, there are 2 issues, 1) app timeout due to lack of user interaction/live viewing and 2) live viewing timeout. I tested live view this morning for almost an hour with no timeout. How it responds to multiple hours, I have no idea and likely isn't a use case the camera was designed for.  That doesn't mean it's not possible, just that it's outside of design parameters.
As for not streaming to the servers first, that has always been a stated necessity. It could be nice to not have that requirement (Baby has a local-only live view capability) but that's not what was designed in. Perhaps future devices will support that if enough folks make suggestions and add kudos in the Idea Exchange forum.
