802.11x
  • 5457 Views
Retired_Member
Not applicable
Can you please confirm if the Arlo Q is 802.11ac compatible. Is there an Ethernet port too?
The Q is 802.11 on the 2.4 and 5 ghz band
The Q Plus has an ethernet cable adapter and can run as POE too
Retired_Member
Not applicable
Appreciate the response. Does that mean it is 802.11n only?
It's 802.11ac compatible in the sense that it will connect to such a router but that doesn't mean it uses that capability. It uses 802.11n since that's more bandwidth than it can use, just as the Pro bases use 100Mb/s Ethernet as well as USB 2.0.
