48935b7ea6eaa
  • 1 Reply
  • 2839 Views
shivadurgah
hi good day is there a limit where the 2feet i have to walk up to the camera, then start to record? i do have it on motion 85% and 90%. i have it on my garage.
Depending on the view / angle /location of the camera...sense is better when motion is across the field of view.
Yes, tho at time there will be a delay in the startup , esp is the signal is on the weak side.
Try it at a higher level , say 94% and use a less amount of view as the PIR for people seems to be better at about 15ft +/-
