"Maximum of 5 camera streams are supported simultaneously" error from time to time
  • 4 Replies
  • 2834 Views
  • 3 Likes
Nachtigall
Once again here - as for others before:
Maximum of 5 camera streams are supported simultaneously. Please stop one stream before starting another camera stream.
Not used the live stream of the Arlo Q Plus the last few days, neither on the App nor on the Web (where only one session is enforced anyway).
Arlo Q Plus, in PoE mode:
HW Version VMC3040Sr6
Serial Number <snip>
Firmware1.9.0.0_269
Restart doesn't help. How i can fix that?
Have you tried both the app and a browser? Try force closing the app and open again.
Nachtigall
Yes, i have tried both - web and mobile app. I have tried force close as well. The only way to fix this - completely remove and setup the camera again. But, it's ridiculous! During this error - the camera is completely useless and not recording anything. I'm totally disappointed and will look for some other brand to buy.
Nachtigall
So, if someone will search how to fix this problem - the only way to go to your camera, physically disconnect from the power adapter and connect again.  If you far away - there is no other solution, Arlo didn't fix this, so your camera will be useless. Also, Arlo's support is horrible. Nobody even tried to understand where the problem is coming from.
In conclusion - don't buy Arlo cameras, there are a bunch of other brands on the market.
Not a solution but a WiFi switch such as a WeMO could be used to remotely power cycle the camera.
  • 4 Replies
  • 2835 Views
  • 3 Likes
