  • 6 Replies
  • 3949 Views
StanPavel
I bought the Arlo Q plus camera a few months ago. I used it with my iPhone without a problem several weeks. Then I wanted to connect the camera with the iPhone of my wife and I did probably something wrong. Since then I lost the connection with my iPhone and have not been able to reconnect it again.
I follow the instructions, enter the WIFI name and password, hit the sync button, display the QR, camera chimes, blue LED is blinking slow (not fast) and a few minutes later I get the message that my iPhone cannot be found.  I depressed the factory reset button as suggested, followed the procedures, but with the same result. I have the camera in a different room than WIFI router. Could it be the reason?
6 REPLIES 6
Make sure you phone is on the same network as the Q is linking to...
JohnWhite2018
The same problem!!!
It worked properly before.
And wi-fi network the same as it use to be on both devices.
Please help.
JohnWhite2018
I've tried many times. It doesn't work(
Are you trying to set up your camera on a new account under a different username? Has the camera been removed from the previous account?
StanPavel
Thank you for your suggestions, James. I suppose my camera has been removed from my account. It does not appear when I open the account.
I could not find a way how to cancel my existing account and how to make a new one.
Please, help.
StanPavel,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
  • 6 Replies
  • 3950 Views
