  • 3293 Views
Matt801
Almost exactly 2 years of working, my Q+ is frozen. Tried everything already mentioned in other similar threads but the amber led is continuously on. Router shows Q+ connected but still camera not responding.
Should I just bin the thing (as it seems to be broken according to other similar threads) or has anyone yet found solution?
ShayneS
You can try performing a factory reset if you have not already.
Matt801
Have tried, does nothing and I mean absolutely nothing..
Matt801
Camera stuck on booting up.. I'm just amazed and disappointed that Arlo doesn't have the fix for this issue or they are unwilling to hand it out.. I quess that's one way to get people to buy a new camera, though probably not an Arlo branded.
  • 3294 Views
