Hello,
I want to buy UK Power adapter for Arlo Q plus, unfortunately i can't found on your website, can you tell me please which power adapter will be good or where can i buy one?
(This power adapter will be ok? Indoor Power Cable and Adapter for Pro, Pro 2 and Security Light (VMA4800))
Regards,
Gocha
I haven't tried one of those to see if it would work - the 90 degree microUSB connector could be a problem if it doesn't fit properly. The charger itself generally shouldn't make a difference - it just needs to supply 5v at ~2 amps. If you have something like that, give it a try.
Thanks for your reply, i will try and let you know, if yes maybe we can help other users to... 🙂
As @jguerdat says, there is nothing special about the power supply for the Q PLus. Anything that does micro USB will hack it as long as the volts are right and there are enough amps.
Third party adapters will be cheaper than the official ones. Don't you have something lying around to try? I seem to have drawers full of these things.
Just another user
Thanks for your advice jguerdat, works fine 🙂
