  • 3286 Views
tingram
I have an Arlo Q Plus and have the CVR subscription - the cameral records for about five minutes, then the recording shuts off.  I can still see the live streaming on my computer but it is no longer recording.  Do I have an incorrect setting somewhere?
The CVR option should be recording on the time line 24/7
ALSO, any triggered events will appear as a color marked section AND appear in the library as a normal recording.
If it isn't doing so, and you have reset the cameras, I fire off a question directly to Netgear via their email/chat and see what they can do for you.
To rephrase a bit, the Q camera constantly streams which is what you see via CVR.  Recording is different - it's based on motion or by manually recording while live viewing.
I just tested mine to see what happens when recording while live viewing. My camera is a bit funky - had to restart it just to be able to do this.  I found that, while the network was showing video being uploaded, an attempt to record for >5 minutes resulted not only in an error message when stopping recording that no recording was going on but also no recording showed up in the library.  This is likely a result of previously being able to record for >1 hour, resulting in a huge video file which Netgear obviously didn't want to have happen.  Why you can get 5 minute recordings without doing anything and I can't is unknown.  Maybe if I had waited, it would have shown up, maybe not.
So, the end result is that currently you can't get more than a 5 minute recording from a Q.  However, you can use CVR to essentially do the same thing.
tingram
thanks!  I'll get in touch with them
  • 3287 Views
