  • 8 Replies
  • 4027 Views
Jarlo737
I keep getting notifications while there is no actual movement detected. When I check the video it looks like the screen refreshes. Similar to a flickering light. Does anyone know how to solve this problem? Preferably without having to need the Smart plan.
8 REPLIES 8
ShayneS
@Jarlo737
What troubleshooting steps have you performed so far? I do not want to suggest anything you may have previously done.
Jarlo737
I set up a relatively small activity zone and set the movement sensitivity to 1.
ShayneS
Have you tried to reboot the base station? If you have done this, you can try and remove the camera from the Settings > my devices > re-add it & test again.
Did you set the sensitivity in your modes and rules? The motion detection test is just a test to be used in your rules.
Jarlo737
I have the Q Plus so no base station. I can try to restart or remove the camera, but I haven't had the false notification for a day now so I'll wait a little before I try that option.
Jarlo737
Yes, I set the sensitivy in the rules. Moreover, that's the only place where I can set the sensitivy. I don't see any other options.
Jarlo737
Could it help if I adjust the Flicker Adjustment? It's now set to 'Auto (50Hz)', but I can also choose '60Hz' or '50Hz'.
I don't belive the flicker setting would help false detections. I would guess that something is flashing in the camera's view causing enough change in enough pixels to trigger the camera. I would try a total camera reset and, failing that making a difference, open a case with support for a potentially bad camera:
  • 8 Replies
  • 4028 Views
