  • 1 Reply
  • 1428 Views
Raynern
Hi, is it possible when setting up a schedule to choose between audio, video or both as triggers. I have a camera pointing to the road which is getting constantly triggered by noises from the room when family are home, but I still want to capture movement alerts from outside. Is it possible in a specific time schedule to disable noise alert triggers and rely just on motion?
Yes.  You create a new mode with rules for all your cameras, and set up those rules to only trigger on motion.  Then you set up a schedule that uses your existing mode when you want audio detection, and the new mode when you do not.
This article might be helpful to you: https://kb.arlo.com/42/What-are-modes-and-rules-and-how-does-Arlo-use-them
  • 1 Reply
  • 1429 Views
